Hvor selges de fp eksosventil til honda nsr?
Hei eg tenker på å bytte ut eksosventilen til fp, hvor kan eg få kjøpt det og er det mye arbeid å bytte? Takk for svar
Mvh Runar
- jontosen
- MC: - Cagiva Mito 125 2005
x - Honda NSR 125 1997 - Location: Førde, Sogn og Fjordane
Re: Hvor selges de fp eksosventil til honda nsr?
Det du treng er boksen som heite TV-78 KBS. Men den er jøvla vansklig å få taki!
DEt eg gjor med min gamle var å ta ventilstyringa frå ein 92 modell (TV-78 Ky4). Og berre skifta om kontaktane frå den orginale (TV124).
Det gjor eg med hjelp av ein frå BCF Forum, so instruksjonane er på engelsk. Men kan slege det ut her om du e intresert.
her er e-posten han sendte meg:
hi,
i assume you're from norway or sweden
you need :
- retractable sheath diameter 3-3.2
- tin soldering (wire)
- soldering iron
- hair dryer
cut the KY4 wires as shown on pict #3 , cut the TV124 as shown on pict #4 and cut the black sheath along
now , begin by assembling the 3 wires connector and think about making union step by step like a staircase (avoid to solder at the same length) as shown on pit #2 . to unite the wires , cut the wire's sheath for 1/2" (1,5cm) slide down one end 2cms of retractable sheath turn cupper together as shown on pict #1 ) , solder the wires then slide the retractable sheath over the soldering and use the hair dryer to lock it .the colours are exactly the same so you cant miss but it's 2 red/white , and it's why i suggest to begin by the 3 wires : black,green,white/red)
when you've done it , put some plastic tape around to insulate this bit . do the 4 wires connector as the 3wires and the light green as a wild terminal .afterwards insulate all wires together . that's it
if you need some more precisions , do not hesitate
cheers
Håpe det hjelpe deg litt
hi,
you need :
- soldering iron
- hair dryer
cheers
"Being second is to be the first of the ones who lose." - Ayrton Senna
